Pajero-200910081214116 Pajero-200910083214036 img_0488 IMG_20200926_105041_1
Расположение компанентов 6G72 Pajero I
Name Symbol Name Symbol
Air conditioner relay A Inhibitor Switch (auto) L
Air-flow sensor B MPI control relay M
Idle speed control servo (ISC) C Air conditioner switch N
Throttle position sensor D Engine check indicator O
Air conditioner temp sensor E Power steering oil pressure switch P
Engine coolant temp sensor F Ignition timing adjustment terminal Q
Ignition coil G Self-diagnosis check connector R
Crank angle sensor H Fuel pump drive terminal S
Purge control solenoid valve I Electronic control unit (ECU) T
Injector J EGR temp sensor U
O2 sensor K EGR control solenoid valve (m/t) V
Рулевой маятник Pajero I
